Ken,
E-mail me the file and I'll see if I can spot the problem.
HU,
I use the difference function more than the solid cutter.
The difference is best when you have one solid you want to remove from another.
The solid cutter works good when you want to trim a solid with just a surface.
I've gotten in the habit of building everything out of solids.
Because it is so easy to do in Onecnc. But sometimes you have to use a surface.
