Originally Posted by gacrwell Just curious. I don't see any mounting holes. How is this board intended to be mounted? I'm guessing, mount to the heatsink and hang the board off the chip? (Is there a mounting hole hiding in the corner behind the header connector?)
Gary |
In most cases, the mounting you suggest should be fine.
There is a mounting hole in the corner between the PMinMO connector and the motor/power connector, and there are no traces in the corners near the SLA so you can drill your own mounting holes as you like in that area.
