Madcam hanging at startup | | Well, here's as much as I know:
32-bit Windows XP SP3 on an Intel Core2 Duo CPU @ 3GHz w/ 2GB RAM
This is a new computer. The initial install of Rhino (SR6) and MadCAM (4.2) worked fine with WinXP SP2. Then my sysadmin updated Rhino to SR7, but around the same time, autocad 2010 and 3d studio max 2010 were installed as well. Rhino will start if madcam is not installed. I removed both rhino and madcam and reinstalled rhino with SR6 and then MadCAM 4.1 and then 4.2. Neither of them work. Tried updating to WinXP SP3 and reinstalling rhino. No luck. That's as much as I can tell you.
Screenshot is attached... |
