Thanks for the help ger21. Its very strange, i went into the config as you suggested and absolute mode was already set for distance, but then i noticed that the initialization string was set to G80, so i put G80 in my code in the line after M3 and surprisingly enough it worked perfectly for the first time! However, when i tried it a second time without changing anything it went right back to the original problem. I have been trying for an hour to get it to work correctly and it refuses to. |
