Old 03-30-2005, 05:55 PM
machintek machintek is offline
Moderator
machintek is on a distinguished road
Good to hear about the two Z axis cables.
Do you have the operation manual? I have to be in front of the machine and need to know which version of software you are using. I no longer get to play with these machines a lot. Also there is a problem if you use collets instead of solid end mill holders. With the solid end mill holders, you can preset all the TLOs. If you use a collet you have to set a TLO after you put the tool in. Not very efficient. The newer software supports multiple work coordinate systems (I am 99 percent sure of this).
George
