  #12   Ban this user!
Old 03-29-2005, 09:16 PM
Laff Riot Laff Riot is offline
Laff Riot is on a distinguished road
Home Depot has all the pieces you need to put this together in a weekend. Even better, they have a working model onsite that you can use for piece to piece comparisons. Take a camera and snap some pics so you know how your jigsaw puzzle goes back together when you get home. We did the whole kit without the saw (ours is for a router) for a couple hundred, you can probably do it cheaper but we overbuilt for rigidty.
The pipe is 1-1/4" Electrical conduit pipe - grab 2 of the tallest ones they stock. The U-bolt is SS model 56-2046-629 - 1/4 x 2"x3" - that has about 1/4 clearance between the pipe and the U-Bolt on all sides. Over in the hardware section pull out trays you will find 3/4 nylon spacers with an internal opening of 3/8ths inch. Grab a couple of these, a short elbow of the 1-1/4 pipe and the u-bolts and assemble them all on-site to make sure your clearances are good. You can adjust pipe, bolt & spacers to suit how rigid you want this system, this is the rig that works for me.
Do not buy the the spacers at HD - too expensive, look online you can get a whole bag for like 15 bucks. You load about 15 of these spacers onto each U-bolt thus keeping it centered on the pipe. The rolling action of the spacer self clears itself of dust and you adjust the u-bolt tightness as desired.
The saw / router holder is a little difficult to explain - just checkout the one they use at Home Depot while your there. If you need diagrams let me know I'll snap some pics.
Worry about success, failure takes care of itself.
