Thread: Need Help! OSP 7000M DNC-DT Setup
Old 02-03-2010, 10:56 AM
Algirdas's Avatar
Algirdas Algirdas is offline
Algirdas is on a distinguished road
How do I manually set the IP address for the OSP?
You can set the IP address and subnet mask on OSP 7000 only manually.
Parameters - DNC/DT parameters.
192.168.0.4 should work in common circumstances. Please, check, if "4" is available in Your subnet. You can enter whatever until what Your router understands instead of "4"
Make sure, You see this group of parameters: search, display select, select.
