Originally Posted by CNCadmin That a good solution, I didn't even think of that one. |
When you offset the line(s) put it/them onto a seperate layer either in your CAD/drawing software or by using the 'layers' feature in SheetCam. Then you can apply a 'process' to just the offset layer.
I find it is often easier to adjust things at the drawing stage than at the 'process' stage.
Larry
