I have had cutter comp problems with several CAM packages and on several controllers. If you really need it then spend some time working out the bugs if you don’t need it turn it off. I find it much faster to repost the code if I change cutter diameters, then to chase a hidden glitch in the drawing. Cutter comp is great if you have large runs and a box full of odd cutters but these days that is seldom the case.
Gary |
