Thread: Need Help! part catcher positioning
Old 01-28-2010, 12:08 PM
caddisfly caddisfly is offline
caddisfly is on a distinguished road
Originally Posted by dcoupar View Post
I believe his machine has a different style parts catcher (the Operation Manual identifies it as Parts Catcher "B"). It is overhead, and can position to either the main or subspindle, depending on the M-code (M10 > main spindle, M310 > sub spindle). Does this sound right, Caddisfly?
I've attached a diagram showing the switches, but your machine may be set to use a timer instead. You'll need to check the Keep Relay Section of your "blue book". If it's set to use a timer, I think you just adjust the stop, not the prox. switch.
In any case if your machine is new, your dealer should be able to help you out with this.
Thanks for the replys.
dcoupar, you are correct. With a little more searching we found the switch.
thanks
caddisfly
