I believe his machine has a different style parts catcher (the Operation Manual identifies it as Parts Catcher "B"). It is overhead, and can position to either the main or subspindle, depending on the M-code (M10 > main spindle, M310 > sub spindle). Does this sound right, Caddisfly?
I've attached a diagram showing the switches, but your machine may be set to use a timer instead. You'll need to check the Keep Relay Section of your "blue book". If it's set to use a timer, I think you just adjust the stop, not the prox. switch.
In any case if your machine is new, your dealer should be able to help you out with this. |
