Old 01-26-2010, 12:50 AM
teronas teronas is offline
teronas is on a distinguished road
I need a little clarification.
According to http://pminmo.com/mach3-setup, To Setup the motor outputs in mach 3...
navigate to the Motor Outputs tab and define the interface as your hardware needs. Check for each axis you plan on using to be Enabled, the Step and Dir Pin Number (DB25 Definition) assinged, and the Step and Dir Port number is set the same as below. (i.e. Port 1) The columns with the RED X need to be configured for the motors to run, the other two also need to be configured and will affect accuracy but not if they run or not.
My question is: Which ports in the DB37 pinout connect to "step #" and "Dir #"?
I am guessing that the it is signx/pwmx from the pinout document, but which is which?
