  #12   Ban this user!
Old 01-17-2010, 05:44 PM
Lasershop Lasershop is offline
Lasershop is on a distinguished road
Originally Posted by M250cnc View Post
Lasershop in Mach3 you set you home location in CONFIG/HOMING LIMITS
There you put your home location
Then at the correct place near the end of code you have G28 Z0 Y0 X0
They will home in the order that they are written so you could swap the X & Y
Phil
I added "G28 Z0 Y0 X0" right after the M30 in the post and it ended up in my cut file. Thanks. Can I simply add it to the tool change section also? I need it to home at a tool change.
