Thread: Need Help! Turret trouble Puma 10S
Old 01-15-2010, 08:30 AM
MTSS Service MTSS Service is offline
MTSS Service is on a distinguished road
Turret Position Problem
Hi There;
I suspect that you may have several issues. One being that if you can index one position at a time and off by one or more tool position you have a mechanical alignment problem.
When you index does the Tool position change on the CRT? Also the second issue would be Encoder Timing issue on the Tool Positioning . Does the Turret have an Idexing encoder?
If it does then I would recommend to continue trying to index the turret until you get to the Number 1 tool position. If it locks down at the number one position check and see if the LED is turn on the encoder for this position.
If it is not , push in your e-stop and adjust the encoder until it does come on and then power the control off and back on. This would only be helpful if there is a Turret Position Encoder. After power back up the CRT should say you are at the Number 1 tool position.
If you have the manuals for this machine there should be a procedure to follow to mechanically and electronically re-align the turret.
Any way post back with any findings .
Larry (MTSS)
