Thread: Fanuc Series 10
Old 03-24-2005, 05:45 AM
kayleesdad kayleesdad is offline
kayleesdad is on a distinguished road
Question Fanuc Series 10
Takisawa TC-2 Lathe Machine Fanuc Series 10 system
The problem I am having is control power not coming on. When I attempt to cycle the power on, the input unit alarms. I have verifed all related fuses are good and that I have to 240vac to the input unit but nothing out. The PIL LED stays green. Not sure if that means I have a bad input unit or that it is alarming for some other reason. The only inputs being used for this unit are the AC input (S&R) and EON and EOFF. I have 240vac at S&R and 22 VDC at EON and EOFF but nothing out. But after getting a fax of the Series 10 power and inputs units schematics, I noticed that PB and PA stay open (RY11). I disconnected the power unit from the master board and the condition stayed the same. I then disconnected CP15 and again the condition did not change. This seems to point to the power unit (POWER UNIT: A16-1210-0510-01), do you agree? Any help you can give me would be much appreciated, thanks.
Control panel part # HR56005-001
Base board: Fanuc System 0 A026B-0083-B501
INPUT UNIT: A14B-0076-B00 1 01
GRAPHIC MPG BOARD: A16B-1210-0800
I/O BOARD: A16B-1210-0820
