OK, sorry about the delay. The way to do this is to convert text to curves. Select the innner parts and move to a new layer. Export out as DXF v10. Import into bobCad and select all then select the optimize feature. Save it. Load the DXF into Mach2, set your layer depts and speeds, generate G-Code and cut. |
