Originally Posted by nash Gentlemen, esp. Rocket and Andre, I need some help in identifying the wires that I've colored in the following photographs.
In the middle photograph (vertical format) are the points 1, 2, 3 and 4 in Red the Phase 1, Phase 2, Phase 3 and Neutral for the main power? Is the small panel in yellow the earth terminal?
In the first photograph, what are points 1, 2 and 3 for?
In the photograph of the Bottom inside panel front, what are these connections? Are these the water pump connections? Well any ideas or hypothesis will be fine. Another thing, whats the right way to connect the 5.5 HP chinese water vacuum pump?
Thanks a bunch,
Nash |
Hi Nash,
In the middel, the 4 poles white connector is for the machine power, the right side of it the one with two kelly wires are the earth termial.
In the first photo, have no idea about the first three, the one with brake in the middle is for the power of servo motors, you need to push it on the top first if you want to use the machine. the one on the right end is a relay, which is for the console power, for the buttons on the console etc.
The one you wrote BOTTOM INSIDE FRONT PANEL, the 3U1, 3V1 and 3W1 are for the water cooling vacuum pump.
