Gentlemen, esp. Rocket and Andre, I need some help in identifying the wires that I've colored in the following photographs.
In the middle photograph (vertical format) are the points 1, 2, 3 and 4 in Red the Phase 1, Phase 2, Phase 3 and Neutral for the main power? Is the small panel in yellow the earth terminal?
In the first photograph, what are points 1, 2 and 3 for?
In the photograph of the Bottom inside panel front, what are these connections? Are these the water pump connections? Well any ideas or hypothesis will be fine. Another thing, whats the right way to connect the 5.5 HP chinese water vacuum pump?
Thanks a bunch,
Nash
