Electronics Enclosure:
My electronics and computer were originally going to be mounted in rack enclosures, but they are quite costly and decided to use the rack but with a rack shelf and standard computer cases. I bought 2 matching cases that fit nicely in my rack.
One holds the PC to run Mach3 and the other has the PS, BOB, Geckos, etc.
I have a couple of relays to control my startup and power estop, I also have a solid state relay that is use to dump DC voltage to a large resistor in estop or power down conditions.
I have a 6 port RJ45 Breakout on the front along with 4 XLR Chassis connectors and a digital DC AMP and DC Voltage meter.
The rack has a tiltable top which I mounted my LCD and Flexable silicone keyboard.
I am also using an Xbox controller in Mach3 to control my machine. |
