Old 01-08-2010, 12:03 PM
Brian FRF Brian FRF is offline
Brian FRF is on a distinguished road
Originally Posted by gmsmachinists View Post
im having a problem on my matsuura 500v with a mx1 controll,,my tool changer wont change and i have tried all the ways to do it...my z does zero out but the atc light does not come on..when i attempt it alarm 400 seq error2 and user msg412 17 m06 error4 comes on everytime..the tool changer doesnt even try to move and i hear nothing like maybe its trying but nothing,,what would cause tis problem and what can i do to fix it..really wanna run tis machine...thanks and look forward to hearing some answers and again thanks
You are using jog, flippping switch on to zero the axis', then jogging z down 2", then up, till it stops. Z zero light xshould come on, as well as atc light.
then do an m19 in mdi.
From there you should at least be able to jog the tool change around. fwiw, T1 is home, so you can do a m6t1, and the tool change should run itself in out/, up/down, and around to get to t1. Also, watch the 3 phase, if its backwards, itll run the tool change carrosel backwards, instead of out. See my post above yours on this.
