What I need is the Ladder Logic that's only supplied by Bridgeport. It is contained on the two Eprom chips in the rear of the machine on the Memory Board. We had a Chip Failure EO1 Eprom. This information on these chips can only be read and re-burned onto another Eprom, If yours ever fails you will be in my boat. They are not contained in any of the parameters, they actually contain what the machine is and what it does.
What I proposed is Having Fanuc CNC come to your facility and/or Shop and pull the memory card, (Maintaining Your full Parameter listings) by backing it up onto there drive and (I will have them make a copy for your records) have them pull the EO1 & EO2 Eprom chips and burn copies of the chip. (I will also have them give you one set). and then replace them and reinstall all your system back to working condition. Plus you get to pick there brains on any issues while there their.
I want to reiterate this: It will cost you NOTHING I just need you to let them do the work for me. |
