Originally Posted by greggv Hi! I'm using Mastercam's mpdypth post, and most of it is fine. Two problems: First tool call is output like this (M03T01S2400$) I need a seperate M06 for the tool, I need the tool designated as T0101 (tool number and tool offset) and I need a seperate M03. How do I do this? The next tool calls are OK, except for the tool number as stated above. Thanks! Gregg  |
I had my post edited for everything I needed except the tool designation. I needed T0101 (for tool one), but only could get T0001 posted out. This isn't a post solution, but it works and I don't have to make ANY edits. Straight to the machine then cycle start. For tool one for instance, I name the tool "101" for two "202" ect. in Masterecam. Tool 11 would be "1111". I just got tired of having to edit especially when I was running a lot of tools. Not a perfect solution but one I can live with.
phoodieman
