Old 03-22-2005, 08:56 AM
ger21's Avatar
ger21 ger21 is offline
Originally Posted by Kitch02
Is it possible to set something up in a jig, and use the probe in a hand held manner to get points of contact eg:- 10mm or 1/2" apart then smooth by manipulation with the drawing software. Or if you had the probe with the roller on the end, could you hand manipulate it to scan the object?
If it would be possible, could you then set the probe to read points at 10mm or 1/2" points? then you could render it with the software like Rhino or similar, this would drop the time considerably. Just a thaugh, remember I am just a newby, I dont know #&*% from clay.
Mike
Most CNC controller software have automatic probing routines. Just place a probe in your spindle, and set up a grid spacing, and let the machine do the work. Here is how to make your own probe. http://www.indoor.flyer.co.uk/probe.htm
There is a thread here on making a manual digitising arm, although noone has actually finished one yet. You can buy them, but they are quite expensive.
