Old 01-01-2010, 12:33 PM
granado granado is offline
granado is on a distinguished road
How do you opto-isolated the USB port?
BR
Antonio
Originally Posted by striplar View Post
I think you can select if it's active high or active low in one of the setup tabs. It should pull down very close to 0v if it's set up right.
You need to give more detail about the enable input circuit this connects to.
For example is it optically isolated or just a TTL logic level input. If it's optically isolated, you need to know the value of the series resistor and the forward voltage drop of the opto LED to be able to figure out what the drive really needs.
Do you have a datasheet you could post for the drive showing this information?
If you are still stuck, I'll brave the cold and fire up my system to see how it's set up in the control panel.
I had posted loads of useful stuff on the Brain Forum but it's vanished for the time being. You really need to opto-isolate all the enables and limits and make sure there are no earth loops. Don't forget that the USB connection from the PC will ground the 0V of your interface circuit! If you ground the 0v anywhere else you will have a whole lot of problems. I've opto-isolated everything including the USB port and now have a stable system. It's still only open loop but that should be fixed with the new update when it finally arrives.
Good luck with your machine.
