Hello Gentlemen..
Was running a part today and caught turret going to tool 11 instead of tool 12 like programmed. E-stopped immediately and reset it. Tried to manually change tool and turret was locked. Turned machine off and restarted and would do one manual tool change but still one tool position off and then turret would lock. Machine does not alarm at all. After playing with it further, you can e-stop and reset and it will tool change one time and turret locks up. You can do this repeatedly with same results and still remains one position off. I took the Turret unclamp solenoid appart and cleaned it..no help. The TIP and TNC switches both light up. The top one stays yellow all the time and the bottom one flashes red when turret is rotating. Any help would be greatly appreciated!!! Trying to get parts out tommorrow and no one can come out and look at till next week.
Thanks...Kenneth |
