Originally Posted by miljnor I wasn't aware that you needed to transform 120v ac to 120vdc |
You would need an isolation transformer even if you want to provide 120vac into the power supply as generally you would make the DC common to ground, if you did this from straight off the 120v supply you would blow the rectifier due to one side of the AC also being grounded.
Al
