Old 03-19-2005, 06:23 AM
Kitch02 Kitch02 is offline
Kitch02 is on a distinguished road
Digitizing probe question for newby
Is it possible to set something up in a jig, and use the probe in a hand held manner to get points of contact eg:- 10mm or 1/2" apart then smooth by manipulation with the drawing software. Or if you had the probe with the roller on the end, could you hand manipulate it to scan the object?
If it would be possible, could you then set the probe to read points at 10mm or 1/2" points? then you could render it with the software like Rhino or similar, this would drop the time considerably. Just a thaugh, remember I am just a newby, I dont know #&*% from clay.
The first step in learning is to ask, the right way to learn is to ask someone who would know.
Mike
