Originally Posted by butwillitwork Also, this much torque at only 2.8 amps, are these things gona run slow? |
With a Xylotex, they probably will. You probably need a drive you can use a higher voltage with. And gearing a stepper may not help get you more speed, because as the stepper spins, for example, twice as fast to double your torque, it may lose half its torque from spinning faster, giving you no gain.
