15" Touch Screen LCD Kiosk System with External Keyboard/Trackball
http://www.cnczone.com/forums/showth...osk#post642652
Unit comes with a SFF Desktop PC inside:
Intel Celeron 2.00GHz
256MB DDR
40GB Hard Disk.
CDROM, Wifi
Microsoft Windows XP Pro COA.
External Keyboard with trackball mouse.
15" Touchscreen Panel EFL-1501X.
Swecoin TTP 8200 Kiosk Thermal Printer.
Built-in Surge protection.
Front mounted headphone Jack.
Dimensions: (H x L x D): 116cm x 69cm x 76cm.
Tossed the thermal printer. Tossed the WiFi Added a dual port card.
Now has 3 LPT ports.
Added an external Cycle Start Button on the machine base.
It is vandal proof (now dust proof too) ex job applications kiosk.
Takes 3 people to lift it. Doubles as workbench.
Ok at upto 1500 mm/min as jerks don't lose steps. I don't need speed anyway. I cut material. Not air.
Win2000 works better than XP (no clunking), but won't install on some Mother Boards.
DMA transfers are below the Mach3 driver (I believe) and this is what causes the clunking - breaks in pulse streams to drivers - reduce max speed helps.
