You could try to apply tape, or if you can score the bottom before you cut through that would work to. I use to work at a exhibits company building exhibits, usually routing did'nt cause chipping but cutting with a saw blade did, depending on the type of blade used.
__________________ Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com |
