Originally Posted by ALLtra Mach Yes, you could in 2008 as well.
When you open a 2nd instance of ESPRIT , and it tells you it does not support it, click the no option and a 2nd instance will open. You can cut and paste and drag and drop! |
I played around with this for a bit today in Esprit 2008. I was not able to copy and paste anything between 2 instances of Esprit 2008 running at the same time.
What am I doing wrong?
What exactly can be copied and pasted between 2 instances of Esprit?
Features?
Operations? (I can save Operations off and use the Process Manager to re-apply them. I'm talking about a direct cut and paste here.)
Geometry?
