It's just frustrating to have the machine working to a point where the playing can get more intense, and then have to go back and start over.
With the help of PlasmaCam tech guys, I followed this path;
Start/Control Panel [Use Classic View]/Device Manager/Printers/
(here is where memory fails me) It is on a machine running XP and I'm on a Vista machine right now, so I can't follow the same path - Damn that Bill Gates!
Anyway, I found that the port is assigned to B000-B007, so I entered Booo in the PlasmaCam setup and used the option to find the device.
It did recognize the machine over several shut-down/start-up sessions but the last start up had found it's brick wall.
I'll just go back to square one and retrace every footstep. This time I think I'll start at the ground, since that seems to be the most common problem.
One more addition I'm thinking about is a UPS to get the cleanest power possible.
Good idea or wasted $$?
Use the UPS for both the PC system and the PC, or use seperate circuits as I've been advised? |
