Hi Muhammad,
I received your message and had sent you "NC studio Version V5.5.60 ENGLISH Setup version " through my email,have you got it???
Please download that software(3.7M).
If any unclear please don't hesitate to let me know,
Best Regards
Mike Wang
mike@xyz-tech.com www.xyz-tech.com
Dear Sir,
How are you. Hope you will be fine and doing good. Sir I have the same problem as discussed in CNCZONE.com. Which stated that
(((I have here now a cnc router from china
but it is not working.
i have install the software from nc studio i think at the good way.
I installed the software and it found the pci card correctly.
I turned on the cnc and then opened the ncstudio software, once i did that the X-Y-Z Axis started to move by them selfs.
when they reached the limit switch's they still continued and started to make a grinding noise so i tund off the main power to the cnc.
when i looked at the software it had an error "limit switch on".
so i think i have bad version of ncstudio
please help me with this))))))
So sir kindly u can send me the NC studio Version V5.5.60 ENGLISH Setup version . It will be so kind of you. I am worried from last 4 months. Thanks In Advance.
Mr. Muhammad Farhan
