Old 03-15-2005, 09:34 PM
miljnor's Avatar
miljnor miljnor is offline
S.N.A.F.U.
miljnor is on a distinguished road
servo tune? I thought that only needed doing when the machine is setup?
I got the machine to run smoothly but backing all of the cutter comp off and m76 to turn monitor function off. also set 101-103 to 1000, 2000, then 3000. finally got it going smoothly but the biggest change was the cutter comp.
it is doing splined 3 axis tool path ranging in segment size from .003 to .040". I have always had problems with this machine and feed rates causing shudder.
If you think a motor tuning is an issue maybe I will get a tech out and take a look..
I would post the code but its quite a large file and splining looks like greek after a couple hundred lines anyway.
michael t.
