Thread: Up and running!
Old 03-15-2005, 07:12 PM
maxxgraphix maxxgraphix is offline
maxxgraphix is on a distinguished road
Up and running!
First homebrew, my plans and mistakes. Who cares? It works and I'm billing jobs already. Thanks for all the support!
Using Mach2 and CorelDraw plus NotePad.
System cuts at 7-10 imp at .5 thick material PCV or wood. Seems accurate enough. I can't tell, so no one else will. Cheap bearing blocks on rods, allthread screws, 270oz nema 23 motors, but at least it's a nice T-Slot frame. Can always upgrade with little mods. Computer case for drivers and power supply. PS is from Grainger 24V 7amp. I drew the plans in Corel, printed out cut templates and cut on a chop saw and drilled with a drill press. We adjusted the machine to .005 tolerance on 4 corners with a dial mic.
ID:	6299   Click image for larger version
ID:	6300   Click image for larger version
ID:	6301   Click image for larger version
