Thread: madcam updates
Old 12-08-2009, 11:13 PM
turmite turmite is offline
turmite is on a distinguished road
Originally Posted by dgoddard View Post
Mike, real simple - you don't mill steel at 50ipm. Depending on endmill size and hardness of material I normally mill between 2 and 6 ipm. If feed calls for 2.7 and MadCam rounds down to 2 the difference is a 25% difference. When running a long job the time difference is noticable. I either have to edit feed rate or adjust rpm. Not efficient. I also do multiple operations with different tools each with a different feed rate. I now have to edit the file to correct each one. Know it is not a big deal for those who machine in metric but for those in inches it is a real pain. This would be a "good" mod for us inch users.
Well, you are right about the 50ipm in steel. Joakim's 5 axis mills it a about 1500 ipm. On the other hand, I read a post on a guitar builder's forum last night where I saw the guy posted his speeds for cutting abalone shell for inlays. 7.5ipm.
"If feed calls for 2.7 and MadCam rounds down to 2 the difference is a 25% difference."
Can you explain what you mean by the above statement? Who is calling for the feedrate? How are you arriving at the called for numbers?
BTW I talked with Joakim today and he said he would take a look at making this available.....I don't know when, or how long it will be, or for that matter, if it can be done with his alogrithems (sp).
Mike
No greater love can a man have than this, that he give his life for a friend.
