Field Coils | | Please correct me if I have this wrong;
When you connect the field coil and the armature coil to the same supply, when the voltage polarity reverses the magnetic fields in both windings also reverse and the motor runs in the same direction.
If the above is true then you have to connect the windings separately so that the direction of rotation can be changed.
robotic regards,
Tom
In a perfect union the man and woman are like a strung bow. Who is to say whether the string bends the bow, or the bow tightens the string?
- Cyril Connolly, critic and editor (1903-1974) |
