Old 06-29-2003, 11:09 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Hi Kong,
At least since the windings show a decent resistance reading, you'll know they aren't "open" (broken wire) and since they do not measure 0 ohms resistance, they should likely not be shorted out either, but there is no guarantee.
Can the seller tell you what application they came from? Maybe this will give you an idea of their power capacity.
I'm more familiar with permanent magnet servo motors, where no field winding is used. You might need a fancier drive amp to run that type, because of the live field windings. Maybe Google a bit and see what kind of info you can come up with on that general category of motor, or survey the online drive amps catalogues and see if they advertise what kind of motors they will run.
