Old 03-14-2005, 06:42 PM
ynneb's Avatar
ynneb ynneb is offline
Moderator
ynneb is on a distinguished road
The latest version of SheetCam is now availiable.
I see that Les has uploaded a new version of Sheetcam.
You can get it from HERE
Hi all,
I have just uploaded V1.2.0 to http://www.sheetcam.com. This release
has lots of changes:
Fixed: Updating the paths when you change the rapid height
Fixed: Tool numbers displayed as floating point numbers on some computers
Fixed: Code snippets in start points now work
Fixed: occasional ATAN2 error when sharpening corners
Fixed: Support file generation. Perhaps it will actually work now...
Changed: Removed a lot of dependencies from the core code. The changes
to the core code may have introduced some new bugs. If you notice any
problems, especially with screen updating, then please let me know.
Changed: In path optimisation - the apply now button now always works.
Changed: Some improvements to zigzag pocketing
Changed: The cutter now rapids down to start depth
Changed: Increased angle threshold slider range for corner sharpening
Added: Some more gouge detection for leadin/out.
Added: Leads are shortened if they don't fit into holes. They are also a
lot less likely to cut into the part if they are in a tight corner.
Removed: Climb cut box in pocketing - it didn't do anything.
Les
