Sir,
With your setup as described, you will have a max available drive force of 1179# available to drive the table. Assuming an efficiency of .8, this becomes 943#. You should have no problem driving the ways. As you probably realize, the stepper's torque decreases with increased stepping speed and is a function of power supply voltage AND the type stepper driver you use!
Regards,
Jack C. |
