Old 11-25-2009, 04:44 PM
BAD DOG BAD DOG is offline
BAD DOG is on a distinguished road
INTERLOCK
SAME MACHINE,,,,,,,,SAME PROBLEM.
WE PULL THE KEY TO GET THE MACHINE SET-UP AND RUNNING.
AS LONG AS THE CONTROL DOESN'T READ THE M30 YOU WILL BE FINE WITH THE DOOR OPEN TO TEST RUN AND SET UP.
ALSO M250 WILL ALLOW YOU TO OPEN THE DOOR TO SET UP,,,, THEN TYPE IN S1000 M3 TO TURN THE SPINDLE ON. IF THE DOOR IS OPEN AFTER YOU HIT CYCLE START TO ACTIVATE THE 1000 RPM, YOU MAY HAVE TO CLOSE THE DOOR TO TURN ON THE SPINDLE. WILL ONLY RUN AT 1000 RPM.
PAIN IN THE BUTT,,,,,,,,, LOCAL DAEWOO DIST. REFUSES TO CHANGE PARAMETER SETTINGS.
A MACHINIST NEEDS TO GET IN THE MACHINE FOR ALL SORTS OF REASONS.
SHAME,,,,,,,, WE HAVE A SHOP FULL OF DAEWOO MILLS AND LATHES. IT'S TOO BAD THAT SUCH A LITTLE THING WILL COST THEM A SALE WHEN WE PURCHASE A DIFFERENT BRAND MILL.
BAD DOG
