Hay Tero,I use 18mm birch for cabinets as they are used on the road.MDF is probably the best choice for home cabinets.I attached 2 pictures.One is a 28Hz subwoofer,it weights 250 Lbs.The outher is a stage monitor.To day I had the side panels of the monitor cnc'd on a friends machine.21 parts on 1 60X60 birch.He ran the machine almost 800ipm with a 1/4" bit.Time for one sheet was 10 minutes.By template and hand router it could take me 10Hrs.
Have a good evening Terro
Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
