Hi Mike
Sorry to hear you got hurt. This is a common source of difficulty with table saws. You need to have a riving knife that is the correct thickness for the saw blade in use. This stops the kerf closing on the blade and kicking back. With thin stuff the blade teeth should be set so that several are engaged with the material being cut either by lowering the blade or by changing to one with more teeth.
Speedy recovery
Pat |
