Old 11-19-2009, 01:55 AM
Kung fu panda's Avatar
Kung fu panda Kung fu panda is offline
Kung fu panda is on a distinguished road
New!2200W 3000~10000RPM BLDC Motor Controller
hi everyone
the pictures is our new products use in mini-machine,controller 2200W 3000RPM、3500RPM、5000RPM、10000RPM (Speed can be made according to the customer's requirements)
Welcome to see and give me some suggestion
Main function:
◆ Start, Stop, accelerate or decelerating, forward and reverse function
◆ A LCD displays real-time speed, the current state, protection
◆ A flow, over-voltage, overload, voltage protection function
◆ Motor temperature detection
◆ 0-10V analog speed control◆ Provide the user interface should choose function. Panel
◆Should provide 485 interface and TTL interface, which can be conveniently and communication
◆With a sudden stop machine, electric switch, protective mask open doors limit protection
◆Speed 400~6000rpm
◆Drivers can access AC110V/220V two kinds of voltage, in the same drive can be switched
www.sangmutan.com
info@sangmutan.com
ID:	93567   Click image for larger version
ID:	93568   Click image for larger version
ID:	93569   Click image for larger version
ID:	93571   Click image for larger version
ID:	93572   Click image for larger version
ID:	93573   Click image for larger version
