you can, BUT be very cautious! first locate Mill_Inch.Operations and make a copy of the original and rename JUST IN CASE so you can restore if needed. Then rename the extension to .mcx in the operations manager you should be able to delete the unwanted operations. This is also a way to set your defaults, but be carefull this is the master default file. It is recommended to change your defaults through your tool manager and control defs. only change these if it applies to ALL machine/controls. Good luck |
