Your file header information is completely missing. I don't think this will solve all of your problems but most of them. I am having a problem with my motion master 5 axis fagor also but i might be an encoder on the Z.. Here is some code you need in your files the most important is G51 E0.01 (look ahead tolerance) with out this everything we be "average" out of spec... You need to download the fagor 8055 programing manual as well obviously.
%TEST R ,-MX,
;(CUSTOMER- )
;(PROJECT- )
;(DRAWING NO- -REV-A)
;(OPERATION- )
;(MATERIAL- ALUMINUM INCH - 2024)
;(CYCLE TIME- )
;(PROGRAMMER- )
;(MASTERCAM FILE- TEST.MC9)
;(DATE- 11-18-09)
;(TIME- 12:15)
;(TOOL INFORMATION)
;(POSTED WITH 10.1811 TOOL LENGTH)
;(SAFETY CODES)
G53 ;CLEAR ALL ACTIVE OFFSETS
G44 ;CANCEL TOOL LENGTH COMPENSATION
G90 ;ABSOLUTE/INCREMENTAL MODE: G90=ABS G91=INC
G49 ;CANCEL INCLINE PLANE DEFINITION
G40 ;CANCEL TOOL RADIUS COMPENSATION
G10 ;CANCEL MIRROR
G17 ;SET PLANE TO X-Y
G80 ;CANCEL CANNED CYCLE
G70 ;PROGRAM UNITS: G70=INCHES, G71=MILLIMETERS
G94 ;FEED MODE: G94=INCHES/MIN. G95=INCHES/REV.
G01 G53 Z-1.0 F100.
G00 B0.C0.
G51 E0.010 ;LOOK AHEAD TOLERANCE (E)
;(START FILE)
T1
;( Undefined )
S18000 M3
G53 Z-1. F100.
;(ORGX54=0,ORGY54=0)
G54
CODE HERE...
THEN... END OF FILE IS
M5
G53 G01 Z-1. F100.
G53 X0 Y0 B0 C0
M30
focusroger |
