Old 11-17-2009, 03:50 PM
WSS's Avatar
WSS WSS is online now
WSS is on a distinguished road
Slammed,
I think you are referring to kerf width. Are you using the burner/tools that came with the program...ie..40amp plasma, 60amp plasma and so on? Those are only close and cannot determine your actual machine's kerf. It will even change with thickness. You will have to measure the kerf on each thickness to be accurate. An easy way to measure is to make a rectangle in the code wizard and cut it with the settings and material you want. then measure the drop and the rem and divide by two. That is your kerf. Make a burner that dimension and drop it on station one or two (depending if you are oxy/fuel or plasma)
WSS
