I don't do a lot a heavy machining so this may not be of any value.
I had issues with the popping sound during tool changes. Now on a monthly basis I disconnect the air supply to the machine (with the machine off) and disconnect the air line at the regulator that goes to the drawbar release and put 15 to 20 drops of air tool oil (I get mine at NAPA) in the hose and then reconnect it. During the next few tool changes you will see a little mist as the air tool oil works it way through the drawbar release mechanism.
So far it has worked well for me and no more popping during tool changes.
Just something you might want to consider if you can't get rid of the popping during tool changes.
John
__________________ 2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/ |
