Originally Posted by rcpilot82 Just checked the program. problem found!! The NC name on the operation in question was not the same as all the others. All is good now!! Thanks for the help! |
Your welcome. I thought I knew what your problem was because I've had the same problem many times. Now that you understand what happens when you have this problem hopefully it will be much easier for you to deal with because I believe you will have this problem again... especially if you work under lots of pressure / multi-task / get interrupted frequently.
