Barry,
The limit switches can either be done with 1 or 2 switches per axis. I use only one, which reads 2 flags, or you can use two and have them read 1 or 2 flags. I always try to use as little in the way of sensors as I can. Home is a different matter. You can use, but not recommended using your travel limits as a home switch. I use slotted switches or sensitive prox for home location. In most applications, home is not near (with the exception of the z axis) the end of travel. Switchs are cheap, easy to install and can be used in a configuraton to suit. Which ever one you decide on, order an extra one or two and keep as a spare. Hope this helps.
Regards,
Glen |
